Engine Performance problem
1994 Chevy Lumina 6 cyl Front Wheel Drive Automatic 160OOO miles
HELLO I JUST GAVE A TUNE UP ON MY VEHICALE AND IT STILL STALL WHEN I BUT IT IN GEAR WHE I GIVE IT GAS WHEN IDLEING IT BOGS
Saturday, June 28th, 2008 AT 8:30 AM
MERLIN2021
MECHANIC
Is the SES light on? Try reading the codes..
Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash...
