You could have a leaking valve cover gasket and the oil is dripping onto your hot engine and burning. Or you could have a coolant leak.
If your engine's temp gauge goes high when you see this smoke, then it's the coolant.
Lift your hood while it smokes and take a look. Look for oil on your engine.
SPONSORED LINKS
Friday, January 22nd, 2010 AT 3:32 PM
