1994 Chevy Lumina Not getting fuel
73,450 MILES • 6 CYL • FWD • AUTOMATIC
LUMINA94
i tried starting today and was unsuccessful when i do try i turn the key and it tries to crank the end result is it sounds like its going to then just stops . 2nd try it tries and pops a few times then sounds like it will run again and then stops ....i tried ether same result fuel pump is working i can hear it ... what do you recommend???? i do
Feb 26, 2010 at 7:34 AM
JDL
  • 16,098 POSTS
Hi, how long since a tune-up? Use a gage and check fuel pressure. Your obd1, you should be able access some mil codes, if there are any? A popping sound could be valve or timing issues?
Feb 26, 2010 at 8:00 AM
