1994 Chevy Lumina Ignigiotn stuck in run position
1994 CHEVROLET LUMINA
98,000 MILES • 6 CYL • FWD • AUTOMATIC
REDSMOMSUE
Could you please explain to me how to remove and replace my ignition...or is there some trick to getting the ignition to turn back and remove key????
May 8, 2009 at 4:01 AM
  • 110,244 POSTS
If the key doesn't turn, it sounds like the tumbler has gone bad. To get to it, you need to remove the steering wheel (if equipped with an air bag, have it done by a professional). After that, you will need to remove a small portion of the steering column to access the tumbler assembly.
You may want to get a repair manual to help guide you. It also will require a wheel puller to remove the steering wheel.
May 8, 2009 at 5:07 AM
