1994 Chevy Lumina dies
146,000 MILES • 6 CYL • FWD • AUTOMATIC
CARGUY2007
Hi, our lumina dies after it warms up. A guy said it might be the catyillic comverter would that be it or something else.
Feb 11, 2008 at 8:08 AM
TBDK87
  • 11 POSTS
Check the ignition module. It is located under the distributor cap. Sometimes the module will fail but work while cold. After it heats up it will fail and you will get no spark and/or gas. It is only held down by 2 bolts and can be taken to advanced auto parts for testing. Make sure you get some dielectric grease to put on it before you reinstall though or it will get damaged by the heat.
May 28, 2008 at 4:22 AM
