1994 Chevy Lumina charging system
66,000 MILES • 6 CYL • 2WD • AUTOMATIC
PUPPETMASTER121
I replaced the altinator and the battery, why is it still not charging the battery?
Dec 18, 2007 at 8:38 PM
  • 75,988 POSTS
What you need to do is have the battery and alternator load tested this will tell the tale what's wrong. Double check all connections and for broken wire and good contact. Did you check all the fuses involved-See below
https://images.2carpros.com/forum/automotive_pictures/12900_lumina_charge_system_1.jpg
Dec 18, 2007 at 8:50 PM
