1994 Chevy Lumina battery
TKO123
Engine Performance problem
1994 Chevy Lumina 6 cyl All Wheel Drive Automatic
i am changing my side mount battery terminals to top mount ones. problem, when i removed the positive terminal there are two wires. top mount adapters only have space for one wire. where does the other one go?
Mar 8, 2010 at 5:30 AM
CARADIODOC
  • 34,413 POSTS
If you mean there is one terminal on top of the other one, the 5/16" bolt will be longer than normal. Just use the same bolt to connect the two terminals to the adapter just as you would attach them to the battery.
caradiodoc
Mar 8, 2010 at 5:44 AM
