1994 Chevy Lumina
120,000 MILES • 6 CYL • FWD • AUTOMATIC
CLARA1989
Just put new rear roters,calpers and pads on, when I bleed the brakes I get a noise when I release the pressure.Brake pedel is spongey, have to press hard on the pedal to stop.
Dec 19, 2007 at 9:10 AM
BLACKOP555
  • 10,386 POSTS
bleed all four ports.
fill up a clear bottle with brake fluid and put a hose on the pedal and submerge one end in the brake fluid, keep going till no more bubbles appear on each side.
Dec 19, 2007 at 11:33 AM
CLARA1989
I had my daughter pump the brakes, bled all four.Is this the same? Guy at the parts store said it may have a bleader on the master cylinder.Don't have the car here right now.
Dec 22, 2007 at 12:25 AM
BLACKOP555
  • 10,386 POSTS
it will have to be driven for a while for them to work again more then likely, go somewhere where you wont put your life at danger and go in reverse slam the brakes and go forward and do the same. it may also be the master cylinder.
Dec 22, 2007 at 12:38 AM
CLARA1989
Thanks, I will try that.I was thinking the master cylinder as well.I let you know what happens.
Dec 22, 2007 at 12:55 AM
