1994 Chevy Lumina
SHARLING
  • 1994 CHEVROLET LUMINA
Engine Cooling problem
1994 Chevy Lumina 6 cyl 130000 miles
Engine runs hot when going up hill for long stretches or when in heavy stop and go traffic. Fan is working-thermostat is new-dont' appear to have any fluid leaks. Could it be the pump?
Wednesday, July 15th, 2009 AT 8:04 AM
JDL
  • 16,098 POSTS
Hello, are you having to add coolant? The temp rating of the thermostat could be an issue. Radiator cap maybe? Yeah, the pump also.
Sometimes with a crossflow radiator, I drain some of the coolant down so I can see a couple of the top coolant passages, minus the thermostat, the coolant flow is immediate, if the pump is working. I only do that if I'm already working on the cooling system.
Taking a heater hose loose on one end and bumping the starter, should show something.
Wednesday, July 15th, 2009 AT 8:38 AM
