1993 Lumina Idling Problem
S4MUS
  • 15 POSTS
3.4L V6, Well, it looks like you have a ton of Z34 or Ordinary Lumina problems. So I will keep this short and simple. Idle's reeaaaally rough when at a stop light and acts like it wants to stall out RPM needle bounces between 0 and a little over 1. There's a really high pitched whining noice coming off the camshafts.
I have replaced these following parts to try and troubleshoot:
1: Plug Wires
2: Plugs
3: Coil Packs
4: ICM aka Ignition Control Module
5: Oil Change
6: Trans Flush & Filter Change
7: Air Filter
8: Fuel Filter
9: Windshield Wiper Blades?!? WTF, lol!
10: Tires & Complete Braking System Overhaul
Codes that are being thrown are:
34 & 48 <
Sep 17, 2007 at 2:06 PM
2CARPRO JACK
  • 11,533 POSTS
34- MAP sensor signal voltage low
48- ? not listed
Has any other work been done to the engine? Rough like a miss? do a comp test first to be sure you are tuning a solid engine. No vacuum leaks?
Sep 18, 2007 at 1:03 AM
S4MUS
  • 15 POSTS
The only thing I know is it has all new seals and the guy I bought it from said the motor had recently been rebuilt. I do know that the comp test came back clean, could it maybe be a timing issue? I know that with two camshafts no coinciding tends to have a issue with staying running. I think the other code was a Knock Sensor Error. I know there is no vaccum leaks other than the power steering fluid tends to go low every once in a while. I have a hinkling that the P.S. Pump has gone bad and the pulley is just spinning the belt free and too fast. Doesn't matter how perfect I get the idling pin set by ear or to the guage it still shudders and acts like it wants to stall and sometimes actually does stall out when coming to a stop. Any further advice or pointers would be greatly appreciated.
Thanks Again!!
Sep 18, 2007 at 5:17 AM
2CARPRO JACK
  • 11,533 POSTS
Has it run correctly since the rebuild? looking at cam timing issues as the culprit. To time those engines the instructions must be followed to a "T" and it takes a few special cam holders
Sep 18, 2007 at 5:52 AM
S4MUS
  • 15 POSTS
It has sounded the same since I got the car a few months ago and then it just started throwing all sorts of codes, first the ICM, now the MAP Sensor and Knock Sensor. It doesn't mis-fire at all though, I wish there was a way I could record what the engine sounded like that way you can hear the whirring/whining noise coming from the passenger side of the motor.
Sep 18, 2007 at 6:06 AM
S4MUS
  • 15 POSTS
I performed a smoke test on the vaccum lines for the vehicle, A/C and Fuel. No leaks what-so-ever, so I'm thinking the cause for the surge in the vehicle is the MAP sensor and Knock sensor combination. Also I set the timing on it and it so far has solved the whining problem I had, it was only off by one tooth on the guage.
Sep 19, 2007 at 12:38 PM
