1993 Chevy Lumina transmission sluggish
199,000 MILES • 6 CYL • FWD • AUTOMATIC
TCBOND
Fusible link (HVAC) replaced; now transmission does not go into gear until warmed up 3-5 minutes; with it removed, transmission goes immediately into gear but slips. Any ideas on the cause? electronics? transmission? Reverse is the slowest to go into gear after warm up.
Nov 22, 2008 at 1:21 PM
  • 110,248 POSTS
Hi:
I dont see any relarion between the work you had done and the transmisson. What is it that you disconnect that makes the trans work better? Also, does it slip when it warms-up? Finally, when was its last service (gasket / filter)?
Dec 3, 2008 at 7:36 AM
