I recently moved from 6000 feet elevation to sea level. My car ran fine for about two weeks, then suddenly lost power. I tested for spark on cylinders 2,4, and 6 (the front three), and discovered there was no spark on cylinder 4. I swapped the plug and wire with no effect, so I replaced that coil. My next guess is the Ignition Control Module. Is there any way to test it before I replace it? any other suggestions?
Sep 26, 2008 at 7:34 AM
