1993 Chevy Lumina I need to know...
OLDSKOOLLOVER19
Engine Performance problem
1993 Chevy Lumina 6 cyl Two Wheel Drive Automatic
The engine on this 1993 lumina has a small knocking sound,an I kind of thought it could be the heads on the engine because also there was white smoke coming out the exaust.
Nov 29, 2008 at 1:56 PM
IMPALASS
  • 3,112 POSTS
Hello –
Yes – white smoke out the exhaust is a sign of a blown head gasket. Do you have antifreeze in your oil? Check your oil to see if it is gaining and then if it is milky then you have antifreeze in it.
Also, if you are loosing antifreeze then that is another indication.
Nov 29, 2008 at 3:40 PM
