1993 Chevy Lumina Fuse box in engine
JUDASPIXIE
Electrical problem
1993 Chevy Lumina 6 cyl Front Wheel Drive 135000 miles
There is a fuse box in the engine with the abs fuse etc. After changing the battery from heck, I noticed that when I put the retaining rod back on that the box moved slightly and the car died. It did this several times. I made sure that the box was attached properly. Yet, I seem to be grounding out. No indicators on dash. No rough idling. So... do you think I have a short? Please answer back. The old beast is all I have...
Feb 26, 2009 at 4:51 PM
TEAG
  • 158 POSTS
Check for any loose or bare wires. Maybe you knocked a connector loose when the box moved. :)
Feb 28, 2009 at 12:57 PM
