Engine Performance problem
1993 Chevy Lumina 6 cyl Front Wheel Drive Automatic
93 lumina 3.1 california car:
what could cause the signal to the fuel injectors to cut out?
it will start sometimes, others not. when it wont run the fuel injectors dont fire but it has spark n fuel pressure.
also at times it wants to fight turning over as if the timing were off causing it to fire at the wrong time.
Mar 13, 2010 at 6:30 AM
