1993 Chevy Lumina Door Locking mechanism
12,400 MILES • 6 CYL • FWD • AUTOMATIC
MARIELHARDIN
My driver's side door latch is broken and I used to be able to open it from the inside until I took the assembly apart to try and figure out what was wrong with it. I undid it and put it back the same as it was and now the door won't open from inside or outside. How do I fix this problem?
Jan 19, 2010 at 3:27 AM
  • 110,248 POSTS
Remove the door panel. Something had to have come disconnected. Check to make sure the linkage is still connected at the latch.
Let me know what you find.
Jan 19, 2010 at 4:06 AM
