1993 Chevy Lumina door lock
150,000 MILES • 6 CYL • FWD • AUTOMATIC
REBRLB98
I changed the driver door handel. It worked fine for a few weeks. One day while driving the door lock stuck. Now I can not open the door from eather side. The lock latch will not slid all the way forward.
Oct 29, 2008 at 9:01 AM
DNAPRORACING
  • 120 POSTS
roll the window down and use a skinny screwdriver to nudge the thin metal bar that works the lock. it connects right below where the key lock is. i had the same issue not too long ago. once you get it unlocked, tear it apart, tighten up everything...
Oct 30, 2008 at 3:20 AM
