1993 Chevy Lumina Coolant leak firewall side of engine
152,000 MILES • 6 CYL • FWD • AUTOMATIC
JOSEPHMJOHNSONJR
Why is my 1993 Chevrolet Lumina 3.1L leaking antifreeze from backside of engine near firewall on left and right sides is there a coolant hose back there or have i cracked the head?
Jan 2, 2010 at 5:17 AM
RAYNL78
did you check your heater core...I am pretty sure it is located on the pass side on your firewall. Follow your hoses from your radiator and your water pump and you should find where they go into the firewall. It it is your heater core you have to go in under your dashboard (nightmare)
Jan 17, 2010 at 1:09 PM
