1993 Chevy Lumina 3.1 litre timing chain syncronization
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
REVKEV316
  • 19 POSTS
I have a 3.1 litre v6 that I am replacing the broken timing chain on and need to know how to syncronize the crank and Cam.
Mar 3, 2009 at 3:10 PM
  • 31,937 POSTS
Hi there, Timing chain set up see pic, mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_Graphic_112.jpg
Mar 3, 2009 at 5:48 PM
REVKEV316
  • 19 POSTS
Hey thanks Mark for the diagram. Do you happen to know the torque specs for the cam sprocket bolts?
Mar 4, 2009 at 1:23 AM
  • 31,937 POSTS
Hi There,
I can post that a bit later to day my time, i need to be on the computer at home as that is where i have to access the data base, as i am in Aust, you will see that as soon as i can get home this evening.
Mark (mhpautos)
Mar 4, 2009 at 7:07 AM
REVKEV316
  • 19 POSTS
I was able to find the specs. Thanks for your help.
Mar 4, 2009 at 7:24 AM
  • 31,937 POSTS
OK,
I was just getting them from another mod who was on line, good luck with the job, re post if you have any problems.
Mark (mhpautos)
Mar 4, 2009 at 7:35 AM
