car is missing very bad and will not idleover one thoundsand rpm also back fires while driving
Jul 7, 2009 at 1:05 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
Has the check engine light come on?
Jul 17, 2009 at 7:29 PM
BABY_BLUZ88
MEMBER
Jul 21, 2009 at 10:25 AM
If the check engine light has been on, I need you to have the computer scanned for codes. When the light comes on, a trouble code is stored in the computer. Take the vehicle to a nationally recognized parts store. Most will scan for free, so there will be no money out of pocket for you. Also, then you will know what is most likely causing the problem.
Jul 21, 2009 at 1:55 PM
BABY_BLUZ88
MEMBER
I bought a computer for my car and it is telling me my cooling sensor is bad, i have already changed the sensor but still running bad. Thats the only code it is giving me.
Jul 22, 2009 at 10:45 AM
THe temp sensor can cause a driveability problem. Make sure the wiring is good to the switch and it is making a good connection.
