1992 Chevy Lumina won't start, no spark
120,000 MILES • 6 CYL • FWD • AUTOMATIC
THE MACHINE
3.4L, shut it off, then tried to start the next day and it would crank but no fire. I have no spark all fuses are good. There are no codes. I was going to change crank sensor, but my manual doesn't show where it is at, it says how to check it. Am I on the right track??
Jan 3, 2009 at 12:46 AM
  • 110,248 POSTS
Hi:
You may be on the right track, but have you checked for power to the coil? Is there a security light flashing when you turn the key? Is the fuel pump working?
Jan 6, 2009 at 9:17 AM
THE MACHINE
found crank sensor on firewall side of motor by alternator vent, it was cracked. After replacement it ran great.
Jan 6, 2009 at 12:13 PM
