1992 Chevy Lumina water leals on driver side floor with ac
1992 CHEVROLET LUMINA
87,000 MILES • 6 CYL • FWD • AUTOMATIC
TAHOE2002
MEMBER
1 POST
Unable to fine the drain hose for the ac system, water is draining in on the driver side floor
Jul 24, 2010 at 5:01 AM
LEGITIMATE007
✓Experienced Mechanic
Hi, I suspect a plugged drainage tube for a/c condensation, look on the firewall and locate the little black rubber elbow. and gently stick a skinny object inside to unplug whatever debris may be causing the plug
Jul 25, 2010 at 8:05 AM
