1992 Chevy Lumina Two Problems
1992 CHEVROLET LUMINA
141,000 MILES • 6 CYL • FWD • AUTOMATIC
ARMORIN
First and formost It no longer shifts correctly, I literally have to manual shift it down to first at every complete start and shift up to 2nd then to drive every time I take off to keep it from shuttering. Also there is some major leak in my power steering, tryed every kind of stop leak and it drains out within 24hours, I could get it on some ramps but im not familiar with that section what should I look for??
Jul 25, 2008 at 10:42 AM
MATT29
  • 10 POSTS
Im not a mechanic or any type of expert, but i would say put some dye you can get from autozone in your power steering and use that to locat the leak, try to have the car lifted so you can see under the pump as well. The stuff iused was neon pink and showed up pretty well. After that was just a matter of replacing the bad part. I would take a good look at the pum/reservoir too.
Jul 26, 2008 at 10:44 AM
