1992 Chevy Lumina Replaced Water Pump
882,500 MILES • 6 CYL • 2WD • AUTOMATIC
GABOY2TUFF
I repalced my water pump, but I still have a leak. I am assuming the casing behind the water pump is cracked. What else could it be behind the water pump that would drain the water. When the car gets hot it sprays water.
Oct 30, 2008 at 11:49 AM
BLACKOP555
  • 10,386 POSTS
the engine block is behind it and if that is cracked on a coolant passage it could cause the fluid to leak out.
check the hoses, is it coming from the block itself?
Oct 30, 2008 at 1:01 PM
