1992 Chevy Lumina RADIATOR FAN MOTOR
14,200 MILES • 6 CYL • FWD • AUTOMATIC
DAVIDSTUART
The radiator fan motor is good, but it will not run when engine reaches operating temperature (fan motor is electric)
Sep 12, 2009 at 2:35 AM
JDL
  • 16,098 POSTS
Welcome to the forums. Does the fan/s run, with the ac on, it should. Also, the coolant temp sensor has some control over when the fans come on. If there is a problem, I'd check the voltage circuits to the fan relay. The pcm grounds the relay in order to energize. Any codes?
Sep 12, 2009 at 3:50 AM
