1992 Chevy Lumina overheating
BAHERE
  • 1992 CHEVROLET LUMINA
  • 6 CYL
  • 80,000 MILES
Have a chevy that I have changed the radiator. Thermostate. Fan relays, water pump also done a pressure test on radiator but car still overheats. No oil in water and car runs to good for a head gasket can you please tell me what it is?
Sunday, December 30th, 2007 AT 11:55 PM
Try bleeding it see below
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Monday, December 31st, 2007 AT 1:00 AM
