1992 Chevy Lumina GAS INDICATOR
127,860 MILES • 6 CYL • 2WD • AUTOMATIC
EYKING
GAS NEEDLE NOT WORKING,STAYS UP.DO NOT KNOW IF IT IS FULL OR EMPTY.
May 19, 2008 at 10:25 AM
BLACKOP555
  • 10,386 POSTS
attach a wire to the signal lead going to the computer and ground it out, if the guage is good it should go down to empty if it doesnt move the guage or wiring is bad. if it does move the fuel pump sending unit in the tank is bad.
May 19, 2008 at 12:08 PM
