1992 Chevy Lumina damaged lug nuts
TMIKEF
Tires and Wheels problem
1992 Chevy Lumina Front Wheel Drive
I had gotten a flat tire and went to change it. I was able to remove 4 of the 5 lug nuts. the last one was completely rounded. I was told to us a chisle to remove the nut but have had a hard time doing it. the nut is completely destroyed and still have not removed it. do you have any suggestions
Apr 23, 2009 at 3:15 PM
DOCFIXIT
  • 18,828 POSTS
May need to have it towed to a tire shop there is a tool that splits nut to remave. The chisel idea may work but don't try and chisel off. Position chisel at an angle to nut about 2 o'clock then smite it repeat , repeat if nut breakes free use vise grips to remove.
Apr 24, 2009 at 8:56 AM
