1992 Chevy Lumina brake peddle to the floor
170,000 MILES • 6 CYL • FWD • AUTOMATIC
RAVE2483
Hi there, My name is Danny, i have a problem with my brakes.
i changed the rear driver brake line, i unscrewed all 4 lines from the master cylinder to find the line i wanted, i bleed all 4 brakes & i still have no brakes, the peddle goes to the floor to a rolling stop! can you help me figure out this problem? what possibilities could make this happen? thank you
Danny,
May 19, 2009 at 1:15 AM
RHALL77
  • 3,361 POSTS
bench bleed the master cylinder then bleed the rest of the brakes, start with the rr, then lr, then rf, then lf. let me know what happends. did you also check to see if there was a leak in the rear wheel cylinders or does this have rear disc brakes
May 19, 2009 at 2:14 AM
