1992 Chevy Lumina
FREAKNASTY
  • 1992 CHEVROLET LUMINA
1992 Chevy Lumina 6 cyl Automatic
What sensor would make my car flood while its idiling?It only floods when idiling. Thanks!
Wednesday, September 3rd, 2008 AT 5:12 AM
SERVICE WRITER
  • 9,123 POSTS
Check your fuel pressure to see if it is in spec. A weak fuel pressure regulator will cause too much pressure.
Any sensor that has an input to the pcm that the pcm needs to make adjustments for the air/fuel mix, included are 02, MAP, Coolant temp, TPS, MAT sensors
Wednesday, September 3rd, 2008 AT 5:44 AM
