1991 Chevy Lumina Vacum Leak?
MELISSA_21_04
1991 Chevy Lumina 6 cyl
My 1991 Chevy Lumina excels by itself after barely pressing the gas pedal. Then when you stop at a stop sign or red light it acts like it wants to die. I am not sure what the problem is but I have been told it might be a vacum leak. It will gradually excel on it's own. Any help you might be able to provide to me as to what this problem is would be greatly appreciated.
Thank You,
Melissa
Jul 21, 2010 at 5:31 PM
  • 75,988 POSTS
Try cleaning out the idle air control valve and test the throttle position sensor as for the vacuum leak spray around the intake manifold flange, if there's a leak the idle speed will change, also check all the vac hoses/brake booster
Jul 21, 2010 at 8:01 PM
