1991 Chevy Lumina My 91 lumina is throwing codes 43 and 53
1991 CHEVROLET LUMINA
BRANDONHAGEN
Computer problem
1991 Chevy Lumina Two Wheel Drive Automatic 380000 miles
i would like to know what the reason would be that my car is throwing these two codes? Any help would be greatly appreciated
Sep 3, 2009 at 7:47 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Brandon,
There are a couple defs for the codes you provided. here they are....
DTC - 43 Electronic Spark Control (ESC) Circuit
DTC - 43 Knock sensor error
DTC - 53 System voltage too high
DTC - 53 Digital EGR Valve solenoid 1 error
So, if you will give a detailed description of you problem we can go from there.
Sep 3, 2009 at 3:10 PM
BRANDONHAGEN
Its been stalling out once in a while and the exaust sounds like its running rough so i wonder if one ofthe sensors is gone maybe?
Sep 5, 2009 at 5:45 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Sorry for delay in getting back with you.
When was your last tune up?
If it is running rough then it could just be that it needs a tune up. With the OBD1 Systems it doesn't give or register a misfire or multiple misfires.
Sep 9, 2009 at 3:57 PM
