1991 Chevy Lumina ip brake light
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAHOOD
ip brake light is on, pedel gose to floor, what should i look for to repair, expense or can i do it myself
Sep 16, 2010 at 2:25 AM
WRENCHTECH
  • 20,760 POSTS
Just the fact that you had to ask that question tells me that you are not qualified to diagnose this issue. It needs to be examined by a professional technician to determine the cause of the loss of hydraulic pressure. Somebody can get killed if this is not diagnosed and repaired properly.
Sep 16, 2010 at 2:36 AM
