1991 Chevy Lumina Code 22
95,263 MILES • 6 CYL • 2WD • AUTOMATIC
SPARKYTJ1
  • 12 POSTS
I had a shop hook my car up to one of their systems and they got back a Code 22 but could not tell me what the code was for.
Jun 23, 2010 at 7:56 AM
  • 75,988 POSTS
DTC 22 TPS circuit and Good Luck
Diagnostic Trouble Codes - 1991
Chevrolet
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Circuit
33 Manifold Absolute Pressure Sensor Circuit (High Sig.)
34 Manifold Absolute Pressure Sensor Circuit (Low Sig.)
42 Electronic Spark Timing (EST) Circuit
43 Electronic Spark Control (ESC) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 Faulty PROM
54 Fuel Pump Circuit (Low Voltage)
55 55 ECM Error
Jun 23, 2010 at 9:49 AM
