If you are wanting to remove the pressure on the belt, most autopart stores have a tool you can rent that will make it easier. It has a flat head and will fit in tight places that a breaker bar or ratchet cannot.
If you are wanting to remove the tensioner, it's normally a 15mm socket and a ratchet
SPONSORED LINKS
Tuesday, December 23rd, 2008 AT 8:44 PM
