1991 Chevy Lumina battery kees dying
SHAYNESCOTT
  • 1991 CHEVROLET LUMINA
  • 6 CYL
  • MANUAL
  • 176,000 MILES
I have a 1991 lumina z34 and my battery keeps dying after about 2-3weeks.I even bought a new one and the same thing happens. The alternator seems fine and now when I go to start it I hear a clicking sound and then my dashboard beeps at me.I have power to everything but doesnt turn over. Got ANY suggestions PLEASE?
Saturday, September 12th, 2009 AT 12:12 PM
JDL
  • 16,098 POSTS
Welcome to the forum. If you have a digital multimeter you can do some checking. Place the leads across the battery posts, the generic specs for a fully charged battery is 12.6 volts. Do that test with everything turned off, take a second reading across the battery posts, engine running. The second reading should be higher than the first, if it isn't faulty alternator or wiring circuit.
Another issue is a battery drain, maybe a light left on somewhere, engine compartment--trunk--interior somewhere. Best time to check for a light is in total darkness. You can check for amp draw, probably 30 to 50 ma max, that is nowhere close to half amp.
Saturday, September 12th, 2009 AT 12:52 PM
