1990 Chevy Lumina water pump
170,000 MILES • 6 CYL • FWD • AUTOMATIC
ERIC ROGERS
i want to know how to change the water pump?
Sep 19, 2008 at 8:06 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:eb62e42270="eric rogers"]Engine Cooling problem
1990 Chevy Lumina 6 cyl Front Wheel Drive Automatic 170000 miles
i want to know how to change the water pump?[/quote:eb62e42270]
remove negative battery cable. Drain coolant system. remove air cleaner (if necessary). Remove serpentine belt. Remove water pump pulley. Note position of locator tab on top of pump for reassembly reference. Remove water pump and gasket, making sure to clean off all old gasket.
reverse to install new pump. Put thread sealant on water pump bolts. make sure locator tab is positioned correctly. Fill with coolant.
Sep 19, 2008 at 9:11 AM
