1990 Chevy Lumina Uneven Brake Wear
12,300 MILES • 6 CYL • FWD • AUTOMATIC
KEYWEMAN
I changed my brakes about a year ago, and changed the rotors on the front breaks. The left front brake pad was worn down, while the right side looked much better. After hearing some brake squeaking recentlyfor a while, I looked at the front pads, and the left side is basically gone, while the right side is like new. I do not remember for sure if I changed the calipers or not last year or not. Anyway, not sure what the problem is with it, but it is frustrating. Thanks
Mar 4, 2010 at 2:33 PM
HMAC300
  • 48,601 POSTS
check to see if the calipers are free and if they are then replaceyour brake hoses on both sides. Your left one may be collapsiing which would cause yoru pads to wear prematurely..
Feb 8, 2021 at 9:44 AM
