When I start my car when cold it runs rough like it's missing and sputtering. If I let the engine really warm up a good 20-30 min the rough idle and sputtering while accelerating goes away and the car sounds pretty good. Pretty much Only runs rough when cold. Usually. Replaced plugs and wires had the ignition module and fuel filter done a few months ago.
SPONSORED LINKS
Tuesday, January 19th, 2010 AT 9:19 PM
SCOTTY DEE
MECHANIC
The PCM may not be commanding enough fuel at cold startup. Possible engine coolant temperature malfunction, vacuum leak present only in cold, i.E. Warped intake manifold etc.
