1990 Chevy Lumina passenger window stopped working
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
JULIUS NEELLEY
For 2 years the front passenger window worked for weeks at a time and failed to work weeks at a time. Then it only worked after using the passenger side control switch. Now it fails to work with both passenger door switch and master sontrol switch. Is this a fuse problem or electrical?
Dec 12, 2008 at 1:43 AM
JALOPYPAPA
  • 467 POSTS
probably not a fuse. May be wiring and/or motor.
Dec 13, 2008 at 12:50 AM
