Are there any codes stored.
IT could be a tcc problem. You can disconnect the sensor connector and drive it to see it the symptom goes away.
Alos check the connector for the MAP sensor. Typically sets a code if bad enough, but not always.
SPONSORED LINKS
Thursday, October 1st, 2009 AT 5:37 AM
