Sorry for the late reply. You need to test when the problem is ongoing. Cranking is starter action. If it cranks good but won't start, have a helper crank it, while you visually check for spark at the plugs. You can use a known good spark plug or spark tester, carry in your glove-box. Pull spark plug wire, use tester in boot, ground metal part of tester to metal part of engine, watch for spark, engine cranking. If you have spark everywhere, use a gage and check fuel pressure. When it stalls, are the dash lites on?
SPONSORED LINKS
Sunday, December 19th, 2010 AT 7:54 PM
