1990 Chevy Lumina motor mounts
1990 CHEVROLET LUMINA
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
GLENN35
if your motor mounts are wore out will it stop your car from going backwards
Feb 2, 2009 at 6:10 PM
DOCFIXIT
  • 18,828 POSTS
Don't believe so might shudder or clunk but would stll back up. Transaxle most likely.
Feb 3, 2009 at 2:47 AM
GLENN35
can it be the transmission. it still goes forward not backwards or is transaxle the samething. can the transaxle be fix with out getting a new or use transmission.whats cheaper to be rpaired a transaxle or a transmission. thanks for ur response very helpful .
Feb 5, 2009 at 8:40 PM
DOCFIXIT
  • 18,828 POSTS
Yes transaxle and trans sameo. Sometimes a used trans is cheaper because a rebuild is labor intensive.Make some calls but first take to AAmco they run a free diagnostic then you will know
Feb 6, 2009 at 7:35 AM
