1990 Chevy Lumina ignition timing
STONYTONE
Engine Performance problem
1990 Chevy Lumina 6 cyl Front Wheel Drive
how do i set the ignition timing
Dec 21, 2008 at 7:11 AM
JDL
  • 16,098 POSTS
You can't adjust the spark timing, if that's what your talking about. I guess you have the v6 with dis ignition?
Can you give more information on your problem?
Dec 21, 2008 at 7:40 AM
STONYTONE
i was told that i had to unplug something w/ orange wire, set the timing, then plug the wire in with the engine running io order to get the computer to reset itsself
Dec 21, 2008 at 2:54 PM
JDL
  • 16,098 POSTS
[quote:36251d4ebf="stonytone"]i was told that i had to unplug something w/ orange wire, set the timing, then plug the wire in with the engine running io order to get the computer to reset itsself[/quote:36251d4ebf]
On some distributor ignition systems, you may be able to adjust the timing. If your ignition system is original, you don't have a distributor.
Dec 22, 2008 at 12:57 AM
