1990 Chevy Lumina Hesitation in motor
93,000 MILES • 6 CYL • FWD • AUTOMATIC
SWTDEE88
I've been told that there is a skip in the motor. I know that the plugs wires and fuel regulator have been changed. WHAT ELSE DO I DO????
Apr 6, 2009 at 2:30 AM
TEAG
  • 158 POSTS
You should replace the fuel filter also and have the injectors cleaned. Most shops can do a fuel injection service. The best ones are cleaners that are added through a vacuum line. The gas additive doesnt really do as good of a job. Your timing could also be a little out. You might wanna have that checked but the injector cleaner through a vacuum line will give you a huge smile when you drive away. Good luck :)
Apr 10, 2009 at 6:58 AM
