1990 Chevy Lumina coil packs removal
20,000 MILES • 6 CYL • FWD • AUTOMATIC
TERRANCE BRADLEY
could you please send pics or anything else that would be of assistance to help me to be able to remove coil packs
Mar 15, 2009 at 1:31 PM
TEAG
  • 158 POSTS
Removing the coil pack is a relatively simple procedure. Theres nothing you can hurt by removing parts around the coil. Once you have the wires off of the coil.... you should have a clear shot at the coil. If there are any hoses or wires from other things in the way.....just move them or disconnect them. The main key to the job is putting everything back where it came from. If you still have problems repost. Also add if its a 3.1 or 3.8. Good luck. :)
Mar 16, 2009 at 6:20 AM
