1990 Chevy Lumina belt
199,000 MILES • 6 CYL • 2WD • AUTOMATIC
RHOMPHH
im about to change my water pump, i have a newer s-belt( about 20,000 miles on it tops) i was told when i put it back on to reverse it or flip it around. good idea or not? the belt is in very good condition.
May 23, 2008 at 11:54 AM
BMRFIXIT
  • 19,053 POSTS
I disagree with that statement
if you are to use the same belt you should mark it so you will be able to return it the same way
May 23, 2008 at 1:15 PM
