1990 Chevy Lumina
OLSON123
  • 1990 CHEVROLET LUMINA
Engine Performance problem
1990 Chevy Lumina 6 cyl Front Wheel Drive Automatic
Engine lopes at idle and does not excelerate properly. I have changed plugs and fuel filter. What should I check next?
Friday, March 20th, 2009 AT 2:19 PM
JDL
  • 16,098 POSTS
Hello, are there any codes? Can you check fuel pressure? As far as the idle, clean the throttle-body, take it off and clean. Check the idle air control system.
Friday, March 20th, 2009 AT 2:56 PM
OLSON123
No codes Don't have gauge to check pressure. It does pump well when I push in on the valve
Friday, March 20th, 2009 AT 3:01 PM
