Trouble with door.
KOUBA93
I recently brole my driver side window in cold weather. I'm trying to get the door panel off of it but unsucessful. Does anyone know how to get a the door panel off for a 88 Chevy Caprice. I've taken the plastic parts and screws out, but it still won't come off. Is there a special trick to it? Thanks
Jan 3, 2006 at 7:32 AM
IMJIMSMITH
  • 13 POSTS
Pull.
On most cars there are little plastic plugs that need to be popped out. You will probably break some or most of them on an older car as I found out multiple times trying to replace speakers and windows. Once you have removed the screws, get a screwdriver under the corner furthest bottom and back and it should start popping out.
You may need to glue the panel back on when you are done, but it should work.
Jan 3, 2006 at 12:43 PM
KOUBA93
I did get those plastic out. The problem is that the arm rest won't come entirely off. It seems that there is some screws on top some where, but i don't see them.
Jan 5, 2006 at 8:20 AM
