Transmission failure ??
WINDSONG1
appears to slip out of drive and into neutral when stopped briefly at a light. When I turned the ignition off, and re-started it, put it in drive it went into gear. and promptly slipped out of gear when I again stopped briefly. When I parked the vehicle, waited and started it again, the car went in to drive, but it will not go into any other gear. Likewise, when I turned off the ignition, waited, started it again, and put it in reverse, it went into reverse, but would not go into any other gear. This problem began without any warning. Could this problem indicate the need for a complete transmission overhaul?
Jan 7, 2006 at 1:41 PM
DARRYL
  • 61 POSTS
hello: Do not know if is slipping out of gear or it is in gear but no clutch pressure on the planatery gear set to make it go. Check for proper transmission fluid lever first of all, possibly something as simple as that.
good luck
Darryl...
Jan 16, 2006 at 1:45 PM
